Amplified Subwoofer
Old Nov 25, 2007 | 02:07 AM
vikingramair's Avatar
Default Amplified Subwoofer
When i comes to stereo i´m really lost. I need your advise if this is a good sub. It´s from WS6.store (sponsor)
INFO:
1993-2002 F-Body MTX ThunderForm Amplified Subwoofer & Custom Box for:Chevrolet Camaro, Camaro RS, Camaro Z28 & Pontiac Firebird, Formula, Trans Am
Subwoofer
1-10" Low Impedance Thunder 4500 Series
Features
- Does not affect T-top storage or rear luggage cover
- Molded in black and installed with supplied hardware and grille
- Enclosure volume: 0.6 cu.ft. sealed
- 200-Watt High Efficiency Class D Amplifier
- Line or Speaker Level Inputs with Smart-Engage Signal Sensing
- Includes Power Wiring and Fuse Holder Also available non-amplified (item CF10) This is Item: CF10AT45
Old Nov 25, 2007 | 03:36 AM
02Z28LS1's Avatar
it will get the job done if you're like me and don't want a system that people can hear from 2 miles away. i personally like the JL Audio subs better, and they make a stealthbox that's loaded with a JL 10W3v3 sub that fits that same area.....only downsides are that it's a good bit more expensive, and isn't amplified, so you would need to supply the amp as well.
Old Nov 26, 2007 | 08:24 AM
dragonrage's Avatar
I'd say go with something else. Get a box from Ian on here and put in a Fi Q12.
