Raptor shift light
I was gonna mount mine in the vent or in the pillar defroster vent, but it didn't seem like it was going to hit me RIGHT in the face like it would if I mounted it where it is now. I can move it down a little. The mount is pretty strong. Modified the mount it came with to fit the hole for the screw in the dash.
Just took this pics for ya.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
its going to be bright no matter where you put it unless the sun is in your face.
I guess I can run the wire extension off the "pink" wire on the ASR under the driver's side pannel and up the A-pillar? That is the plan for now. When I get home from work tonight, I'm going to get the A-pillar off and see what I've got to work with.
If there is a keyed 12v for the trunk popper, that would be by far the most simple. Taking the pillar off is a piece of cake. To hold the shift light, cut the fins off the defrost vent and it will snug up perfectly.
What wires did you tap into????
