How do you remove stealthbox!?
Old Jan 10, 2008 | 04:41 PM
Ryan33187's Avatar
Default How do you remove stealthbox!?
How do you remove the stealth box... I'm trying to chaing my taillight bulb, but I cannot get to the other **** to take it off. So I figure I have to take the stealth box out, but the problem is I dont see where it is screwed in or anything. I bought the car with it in there so I have no clue where it is. Looked around online and saw it was at the bottom, but I dont see a bracket or anything. Ripped all the carpeting out around it besides the t-top area. I took off the driver side t-top bracket, but am unable to pull the carpet out form under neather the box.
Old Jan 10, 2008 | 05:00 PM
02Z28LS1's Avatar
you may need to remove the sub from the enclosure, since they may have screwed/bolted it down from the inside.
Old Jan 10, 2008 | 05:37 PM
KEE AUDIO's Avatar
^^^Exactly. Most are just put in place because they are a tight fit but if your having trouble getting it out it must be screwed from the inside.
Old Jan 10, 2008 | 07:05 PM
Ryan33187's Avatar
Yep was screwed in on the inside. Man what a pain in the A$$ to change a taillight bulb.
