Could someone post the QTP Pin outs please?
Old Jul 3, 2003 | 01:54 PM
Scalpel's Avatar
Default Could someone post the QTP Pin outs please?
Could someone post the pin outs for the prongs on the bottom of the QTP Electric Cutout switch? Thanks.
Old Jul 3, 2003 | 02:36 PM
slow's Avatar
Default Re: Could someone post the QTP Pin outs please?
I do not have the pinouts, but my understanding is the Qtec uses a reversing of polarity to open/close the cutout.
If the switch has 6 wires, then connect like this.
- - - (123)
- - - (456)
Connect 1 and 6 together
Connect 4 and 3 together
Connect 1 and 4 to the cutout
Connect 2 to +12
Connect 5 to ground (reverse 2 and 5 if the switch works in the opposite direction you want it to work)
Hope this might help.
Ryan.
Old Jul 3, 2003 | 03:27 PM
Scalpel's Avatar
Ryan, I assume this would work with any DPDT switch,r ight?
Old Jul 3, 2003 | 03:34 PM
Scalpel's Avatar
This really pisses me off. I got my new motor on the cutout back b/c the old one fell out. It worked fine, 10 minutes later, switch dies. It gets power to it but it doesn't light up or motor the cutout. I think any standard DPDT toggle would do it minus the fancy lighting.
Old Jul 3, 2003 | 09:33 PM
slow's Avatar
it should work.
I have sold a few custom switch panels for Qtecs, using the same switch that NX uses in their switch panelfor their opener, and nobody has had any problems
it is just a dpdt momentary/off/momentary switch.
Ryan.
Old Jul 4, 2003 | 11:05 AM
Scalpel's Avatar
Ryan, you nailed it man, thanks. Works perfectly. BTW, for those that may have a switch fail, you can get one at Radio Shack, (w/out LEDs), part # 2750709 a DPDT Spring Return Center Off Toggle Switch
Old Jul 4, 2003 | 09:12 PM
slow's Avatar
glad to be able to help.
That is my next mod, already have the switch installed and wired for it.
http://www.fuelslut.com/mem_pics/switchsample.jpg
Ryan.
