car dies when blinker turned on
Good luck with THAT electrical problem.
Possible short to ground when the blinker is put UP?
The turnsignal thingy is FUBAR?
When did it start?
Your right indicator is on solid because you have a bulb burned out or a corroded socket on that side. Replace the bulb first and then move on to diagnosing the rest of the problem. BTW, does the car die when you use the hazard flashers?
I had a similar problem on my 94 GP. When I hit either blinker, voltage went berserk. Turns out my junction on the fenderwell where the battery and such connected (there's a jump post there) was dirty. Cleaned and all problems gone.
Have you tried changing the blinker fliud?
just put some in the gas tank, and some in the blinker fluid box beside the flux capacitor
LMK how it turns out for ya
Start with the bulb, and just check for corrosion and grounding issues all the way up to the wire source.
Good luck!
The guy who owned the car before me tried to make the lowbeams, highbeams and fogs come on at the same time. Unfortunately all the lights except the driver's side lowbeam were really dim. And whenever i hit the highs or turned on the fogs the engine would die. I took it to get fixed and the guy told me that there was a floating ground and the fog lights and highbeams were wired directly into the low beam wiring harness.
A little different kind of problem but I hope that helps
