replacement speakers for monsoon system
Old Jul 9, 2003 | 12:05 AM
franny40's Avatar
Default replacement speakers for monsoon system
I want to replace the speakers behind the seats(the 6.5 inch) but all the aftermarket ones are 4 ohms and the stock ones are 2ohms, I am staying with the stock deck i just want to replace those speakers for a little better sound. Any help will be greatly appreciated.
Old Jul 9, 2003 | 08:42 PM
franny40's Avatar
Default Re: replacement speakers for monsoon system
any help?
Old Jul 12, 2003 | 09:04 PM
VADER666's Avatar
Franny40,
Unfortunately, GM didn't make this easy for you to do.
Because the stock system is amplified and is designed to work with the stock monsoon speakers, you're kind of stuck with them unless you are willing to make additional changes in your set up. If you are then, I recommend replacing the stock head unit, or adding an amp to power your "new" speakers with the stock cd player etc. I work for an electronics retailer and this is sometimes the best option, although, there may be other options worth considering. If you want more help, pm me etc.
Good luck
-V-
Old Jul 13, 2003 | 12:56 PM
franny40's Avatar
Thank you for the help. I am going to get the stock ones replaced under warranty, so until then i am going to go stock on the audio for now. maybe later i will go aftewrmarket.
