welding on car...do I need to unhook system?
Old Feb 8, 2008 | 12:23 PM
Creman's Avatar
Default welding on car...do I need to unhook system?
I need to weld some subframes on the car using an ARC welder. It's obviouse I need to unhook the batter as to not cause trouble, but I don't know much about amps and stereo systems. Should I unhook them as well, remove fuses etc. to make sure there are no problems, or will it be fine?
Old Feb 8, 2008 | 12:36 PM
Gordon0652's Avatar
As long as you un hook the ground from your battery you should be fine.
When i did welding on my T/A i unhooked both battery termanls for just the extra safty.
Becareful around lines. Good luck.
Old Feb 8, 2008 | 12:43 PM
Slvr00Bird's Avatar
If you unhook the ground from you're battery you'll be fine... If not, you may pop your airbags...
