anti-theft problem
whats happening is when i try and start my car the security light pops on and it will not let me start the car and ive tried a new key and new keyless entry.
please if anyone can help me ive very close to trying to rip out the security system.
If you've already tried your other key then chances are the problem is with the ignition cylinder contacts. Try cleaning them first. Use some spray contact cleaner in the ignition cylinder and work it in by sliding your ignition key in and out. Give it a few minutes to dry and then try starting the car.
mine went out over time ad got to the point where it would not crank after several tries . to correvt this you will need to find out the correct resistance as gm uses 13 different resistors . all you got to do is undo under the dash , find a orange tube . the tube has the two wires that go to the ignition cyliner . soler in the resistors and it will let you be able to bypass your security .
do a search as i did a write up with some pics a while back .
the tile of the thread is VATS taking a crap
just scroll down and ignore the rude comments made .
edit: bumped it to the top of the general maintenace and repairs forum .
edit : it is working now so here yall go also fixed the pics .
https://ls1tech.com/forums/general-maintenance-repairs/502913-vats-taking-crap.html
