help rear sail mids!!!!!!!!
Old Feb 12, 2008 | 06:50 PM
shaun's Avatar
Red face help rear sail mids!!!!!!!!
hey guys i need your help. im trying to wire up some rear fill and i have a mb quart dse 61/2 componet set laying around so im going to use those. now my question is should i use the x overs that came with the set and the tweeters or just use the woofer by it self and run it off my 4 channel sort of like a mid bass set up. the woofers that came in the set are mb quart dwe 160 sp's. i have a mb quart premium series componet set with the new tweeters they got so i have plenty of highs in my front stage so i dident know if it was worth useing the tweeters and x overs or just useing the woofer by it self. i have a mtx thunder ta 5604 that puts out about a 100w at 4 ohms so its plenty power for the front and rear. so should i wire up the tweeters and x over or just the woofers? thanks guys. oh and these are going in the rear sails.here is a pic. i know there not as good as the ed7's or cdt's but they do get loud and im not realy looking for heavy bass just good mids.
Old Feb 12, 2008 | 07:11 PM
Eskimo's Avatar
if anything, I'd use it as a rear fill. Use the crossover from the set, or if you amp will do a low pass at around 1k and a high pass of ~80hz, you could start there, with the level lower than the front. That's the only kind of rear fill I personally prefer...
Leave the tweeters out though...
Old Feb 12, 2008 | 08:27 PM
KEE AUDIO's Avatar
^^^^Plus one for what Eskimo said! It is a matter of preferance though. Try it without and see what you think. I think you would like it better without the tweeters. For the record MB Quart is a fine quality speaker with good SQ so you should be ok!!
Old Feb 12, 2008 | 08:49 PM
pentavolvo's Avatar
I agree use crossover and just dont connect tweeter
Old Feb 12, 2008 | 11:21 PM
shaun's Avatar
i wired every thing up and it sound good i judt need to get my bigger amp in and i hasent come in yet so i only got 70wx4 for now till hopefully friday it will come in.
