Defroster
Old Feb 26, 2008 | 11:42 AM
4mula4ever's Avatar
Default Defroster
On my 00 camaro i turn the defroster on and it stays on for about 20 seconds then shuts off and wont turn back on until I turn the car off then it does the 20 second life thing again. Any ideas?
Old Feb 26, 2008 | 02:13 PM
2001NBMZ28's Avatar
Assuming your talking about the rear defroster. When it shuts off try your power seat and see if it's dead too (same circuit) - if it is probably just a weak circuit breaker and resets itself. Some people replace the breaker with a 30 AMP fuse.
Old Feb 26, 2008 | 03:00 PM
4mula4ever's Avatar
alright, ya i was talking about the rear one, ill try that next time.
thanks
Old Feb 26, 2008 | 06:29 PM
CruzinCobalt's Avatar
try cleaning the contacts in the back where it plugs into. Some crud was built up on mine and after i brushed it off it worked just fine.
Old Feb 26, 2008 | 10:10 PM
wssix99's Avatar
Save the manuals!
I had the same problem on another Pontiac and had to replace the solid state defroster timer. (This one is supposed to time the cycle for 10 minutes and then 5 minutes for every other time you press the button.)
