Please help steering wheel controls
Old Jul 17, 2003 | 10:28 AM
SoCal LS1's's Avatar
Default Please help steering wheel controls
I have a 98 z-28 without steering wheel controls and was swapping it for a 2000 with steering wheel controls. I understand you have to change over the abs hub with the steering wheel controls but do not know how to wire the steering wheel past that point. Did the stereo come with a wiring harness that is not used under the dash also what will I need to do inorder to hook the wiring up. I noticed with the steering wheel controls there is a fuse designated in the side of the fuse panel but my car does not a fuse there. The 98 deck is a monsoon along with the 2000. Also to disable the abs without a light I have heard the resistor is a 2ohm. Is that 2k ohm.
