remote wire
Old Mar 2, 2008 | 11:34 AM
SSMikeLS1's Avatar
Default remote wire
where do you guys get the ignition signal power at to turn on an amp using the monsoon h/u
Old Mar 2, 2008 | 02:32 PM
WhiteBird00's Avatar
Ungrounded Moderator
I was going to say use the pink power antenna wire because you didn't say what kind of car. But I assume from your screen name that you have a Camaro which doesn't have the power antenna wire. You can add it - the head unit has the output, there's just no wire connected to it. Or you can use any ignition controlled circuit that's convenient (behind head unit, under the steering column, at the BCM, etc.). I can't think of one that's at the back of the car though.
Old Mar 2, 2008 | 10:59 PM
Forklift's Avatar
check the sticky , itll show the wire and pin location
