Help with ignition tumbler
2. Remove the steering wheel
3. Insert ignition key into the cylinder but leave in the LOCK position
4. Remove the lock retaining screw (at the 12 o'clock postion in the steering column)
5. Disconnect retainers and clips holding the VATS wires and pull the harness up through the column.
6. Remove the lock cylinder.
However, this won't solve your security problem unless the other column happened to have the same resistor pellet in the key (1 in 15 chance). Installing the ignition cylinder from the other column and using the other key will not match the programming in your BCM and your car will not start.
