Details of how the steering wheel controls work
If I hook the positive side of a multimeter up to the steering wheel control wire and the black side of the multimeter to a ground, I get voltages under 5 volts when I press buttons.
If I take the steering wheel wire out of the harness, hook the positive side up to the steering wheel wire, and hook the black wire up to a ground, I get like 11 volts. It doesn't change based on which button is pressed either.
So I'm confused. It doesn't look like the steering wheel wire is directly responsible for the different voltages. It only provides different voltages when it is attached to the harness.
This is a problem because I would like to disconnect the steering wheel controls from the head unit and use them with another piece of hardware.
If you want to use the switches for some other purpose you'll have to build a logic circuit that can determine which resistor(s) are in the circuit at any time so that it can respond to the switches.
