Dynamat ......
Old Mar 11, 2008 | 04:13 PM
TX_Stang4lunch's Avatar
Default Dynamat ......
What areas should i dynamat ....this stuff is expensive so i dont want to waste it.
Im looking to eliminate as much exhaust, motor, and suspension noise as possible.
pics???
Old Mar 11, 2008 | 05:53 PM
jebcamaro's Avatar
I`m in the process of installing some dynamat extreme right now. Found the bulk kit on epay shipped for $120. Check out my ws.6 major audio install thread to see what I have done so far. I just finished up the passenger door today. I don`t know if I`ll get towards the rear yet. I`ve used 4 sheets out of 9 on the doors. I bought one bulk kit, but ordered another one the other day. I don`t want to put anymore than I have to due to weight and cost.
Old Mar 11, 2008 | 06:04 PM
dragonrage's Avatar
Well, too late to say this now, but if you want sound deadening in the future for less money, go RAAMMat.
Old Mar 11, 2008 | 06:23 PM
ultraz's Avatar
do doors first of all....... it helps the most
Old Mar 11, 2008 | 06:46 PM
crap, i paid 200 at frys ...car toys was 270 ...craziness
Old Mar 11, 2008 | 07:37 PM
dragonrage's Avatar
I paid $120 for 15" x 50'
Old Mar 11, 2008 | 07:42 PM
porksoda's Avatar
I used the Elemental Designs Edead sound deadener. Got it for pretty cheap and it does its job VERY well.
As said do your doors first and then the hatch area. Just knock on the big flat pieces of sheet metal and if it makes a "ping" noise then lay it down. If it sounds more like a thud then it shouldn't need it too bad. Do the "ping" areas first.
Old Mar 12, 2008 | 11:44 AM
kmgsix08's Avatar
well unfortunately, you pretty much gotta dynamat the whole car for you to really get it quiet. but i would say start with the doors and then hit all around the wheel wells in the back next to the sails and rear deck speakers
Old Mar 13, 2008 | 11:05 PM
aggiebutter's Avatar
If you search the forums, you'll find one that suggest using a product from Lowes that is actually pipe insulation. It is exactly the same material as the Cascade sound deadening material used for the floor and trunk. About $15 a roll and you can do your whole car with 5 rolls. I bought some cascade door kits to do the doors with, because the insulation probably wouldn't be good with the moisture. This will save you a ton of money.
The Skew at Lowes is 2829
Old Mar 14, 2008 | 07:21 AM
WhiteBird00's Avatar
Ungrounded Moderator
It's SKU. It's an acronym for Stock Keeping Unit but is used interchangeably with "part number" or sometimes PLU (Price Look Up).
Old Mar 14, 2008 | 01:23 PM
Doom's Avatar
The doors really made no difference, at least to me. However I def. recommend the trunk area including useless space on driver side and the spare tire area, as there is nothing there but metal and a hole in the bottom. You can literally see the ground if you take the panels off. This significantly reduced the noise from the 4" mufflex and improved bass quality from the sub.
Old Mar 14, 2008 | 03:48 PM
well i dynamatted the whole damn car ...... with exception of areas i will be welding the roll bar in .... i ran out of this stuff ( becouse they give you so little ) and purchased a diffrent brand from jegs .... so far my sound deadening project is up to 389.00 .....
