Speaker replacement question
Old Mar 22, 2008 | 02:56 PM
Twigs's Avatar
Default Speaker replacement question
Ok, I have researched this for almost 2 weeks. I am going to be getting replacement speakers for the door panels and sail panels. I have a 2000 WS6 with monsoon. I will be using the stock head unit, amp, and its trunk area speakers.
Heres what I plan to use: CDT component speakers....what size will fit my car on this page http://www.keeaudio.com/id47.html
CDT Midbass Driver EF-6 (CL-E6) 6.5"
Now to my question. If I plan to get an aftermarket amp, a stealth sub, and an aftermarket amp, would these speakers still sound good? Or would I have to buy new speakers when I do the rest of the system?
Old Mar 22, 2008 | 05:02 PM
Breathtaker's Avatar
If you plan on replacing speakers ONLY (from keeaudio) then you'll be fine, ask him he knows his stuff, now getting an aftermarket amp, a stealth sub, and an aftermarket amp with or without these speakers will sound like **** anyway without an aftermarket HU (was it also included on your list?), why don't you pm kee since it is his business and goods?
Old Mar 22, 2008 | 05:10 PM
Twigs's Avatar
oops... meant aftermarket head unit instead of 2 aftermarket amps >.<
Old Mar 22, 2008 | 05:22 PM
haha I was like "say what?"
Kee is the only one who can answer your question since it is his stuff, pm the guy.
Old Mar 23, 2008 | 08:30 AM
KEE AUDIO's Avatar
Hi guys! For most people on here, replacing the HU, speakers, and adding a stealth sub would do fine. This definetly is a vast improvement in sound quality and volume level.
In fact I put those same speakers in a clients car (02 T/A) not long ago and he still had stock sail panel subs. The problem we ran into was that the subs now sounded like garbage compared to the CDT drivers in the doors. We'll be fixing that with some new subs soon as I get my new order in.
As I've stated before the Monsoon amp is not that bad....it's just fed a distorted signal from the stock HU so it amplies what it is given. Put a quality HU in place you are now amplifying a cleaner signal. Combine that with better quality speakers and you are now able to take advantage of that cleaner amplified signal. Add the stealth sub to round out the low end bass and you have a well rounded system that sounds good at high volume while still retaining the stock amp and wiring.
The speakers (CL-E6) are more than up to the task of aftermarket amplification. They work well with the stock system but really shine with a quality aftermarket amp. They have features like a carbon treated cone structure, cast frame (not stamped), rubber surround, 26mm voice coil, ceramic 14.6oz. magnet and of course CDT's Contoured Dispersion Technology that is engineered into every speaker. Here's what it means at the bottom of the page in this link:
http://www.cdtaudio.com/less_is_more_08.htm
