Fuse box hot spots
Old Mar 26, 2008 | 05:20 PM
hanzel69's Avatar
Default Fuse box hot spots
Hey, I'm installing some guages, I want to use fusable links, just plug into the fuse box. I need to know which one is when the car is on only and which one has power to it constantly. If anyone can help with this, I'm trying to make it clean. My last car had crap spliced all over. Any help is appreciated. Thanks.
Old Mar 26, 2008 | 07:35 PM
WhiteBird00's Avatar
Ungrounded Moderator
There are three ports in the fuse box that are intended for installing accessories. They are labeled BATT (constant battery power), IGN (power when the ignition is on), and ACCY (power when the ignition is on and during RAP operation - after the ignition is turned off before opening a door - like the radio). They are all single spade (flat) terminal ports.
I would recommend inline fuses rather than fusible links. Fusible links are a pain to replace if they burn out.
Old Mar 27, 2008 | 08:42 PM
hanzel69's Avatar
Exactly what I needed to know, Thanks!!!
