How to turn off the stock security system?
Old Jul 27, 2003 | 12:38 PM
tals1's Avatar
Default How to turn off the stock security system?
How do you turn off the stock security system on a 98 TA?
Old Jul 29, 2003 | 10:26 AM
tals1's Avatar
Default Re: How to turn off the stock security system?
I really would like to know...anyone!?
Old Jul 29, 2003 | 05:26 PM
01 ls1 z28 DA BRONX's Avatar
press the unlock botton?
Old Aug 5, 2003 | 09:01 AM
onehardmaro's Avatar
Using the unlock button on your remote or manually locking your doors. The power locks activate the sercurity system when used to lock doors when key is out of ignition and door is open.
Old Aug 7, 2003 | 12:18 AM
maddboost's Avatar
do you want to deactivate your factory alarm all together?
Old Aug 13, 2003 | 06:15 PM
tals1's Avatar
Ya, how do you deactivate the alarm all togather?
Old Aug 15, 2003 | 10:13 AM
yellowpontiac's Avatar
i'm having problems with my anti-theft system also. right now i can't even turn on the car. is there anyway to disable it all together. need to start my car quick.
Old Aug 15, 2003 | 02:46 PM
Rhino's Avatar
Does the security light come on when you're trying to start the car? If so, first of all try cleaning the key, strangely enough this helps quite a bit of the time.
If for some reason the chip reader in the tumbler is out you can wire in a resistor, in line, with the same value as the chip in the key. Although, this method is a little hacked together.
can you expound on your difficulty a little bit?
Old Aug 18, 2003 | 06:40 AM
the securtiy light does turn on when i try to start the car. can u elaborate on that hack u talk about.
Old Aug 25, 2003 | 08:20 PM
tals1's Avatar
the security light is on when I get in the car most of the time...not when I put the key in..it want start and I have to wait about 3 min before it resets...it is ticking me off! How can disable the whole security system??? I'm so tired of this crap!
Old Aug 20, 2005 | 09:17 AM
01badbird's Avatar
having same problem have you found out anything?
