Using remote wire from the amp connections?
Old Apr 6, 2008 | 12:36 PM
98boxer's Avatar
Default Using remote wire from the amp connections?
Im installing another amp to my system for the front speakers.
Can i use the remote wire from the 1st amp, and just tap into that wire and use it for my other amp, instead of having to tapping into the remote wire from the headunit. I have a pair of rca'a that don't have the remote wire attached to the rca wires.
Old Apr 6, 2008 | 03:29 PM
pentavolvo's Avatar
yeah you can do that. any more then 2 amps and you should get a relay
Old Apr 6, 2008 | 05:22 PM
98boxer's Avatar
thanks, i should have this done next weekend
im assuming this would also work with the power cable and add another fuse protector for the 2nd amp?
