bad battery, alternator, or what?
Old Jul 29, 2003 | 12:46 AM
vhgjk123's Avatar
Default bad battery, alternator, or what?
Today i while i was driving i noticed my radar detector kept making weird beeping noises at me. Later on i noticed on my battery gauge next to the fuel gauge that when i started the car it would be in the red. After driving for a while it would hover between the red and 13. My radar detector worked fine after while it hovered between the two. I just got a new battery in May and since its acting weird while its running I was thinking maybe the alternator. Also, I have the ASP crank pulley but not the alternator pulley. What do you guys think?
Old Aug 9, 2003 | 12:23 AM
Tom L. Busby's Avatar
Default Re: bad battery, alternator, or what?
I have been told that the alternator has 3 diodes. After the first one fails you have what you see, 12 or so volts, and in the next few days the voltage will go down to 8 or 9 and a couple minutes later the 3 diode will fail.
Old Aug 9, 2003 | 12:31 AM
shadowSS's Avatar
Yes Get the alternator pulley it will overdrive the alternator. The problem is when its idling is that its trying to pull more amps then the alternator can make.
