Steering controls
Old May 6, 2008 | 10:58 PM
Irocem99's Avatar
Default Steering controls
Is it possible that both are out at the same time?
Old May 6, 2008 | 11:19 PM
enos44's Avatar
what exactly are you asking?
Old May 7, 2008 | 02:37 AM
proelky's Avatar
Most likely you've blown a fuse...They generally don't both go out with one shot...
Old May 7, 2008 | 06:35 PM
Irocem99's Avatar
which fuse is it,do you know? Everything else works..
Old May 7, 2008 | 08:15 PM
WhiteBird00's Avatar
Ungrounded Moderator
The one labeled "STR WHL CNTRL"
Actually, there's two labeled that - fuse #3 is for the switch function, fuse #13 is for the switch illumination. They're both 1-amp fuses.
Old May 8, 2008 | 04:46 PM
Irocem99's Avatar
Thanks whitebird..I wouldn't have asked the question,but I don't have my car..Should have it tomorrow. The shop is on their 3rd set of 3:73 gears,their having a problem setting them up..Obviously they don't know what they are doing..Now a rear end shop has it..I need a drink even thinking about it..
