Replacing bulb in door handles
Old May 16, 2008 | 01:58 AM
toslo5o's Avatar
when are these lights supposed 2 come on? i've seen mine come on but it seems random....
Old May 16, 2008 | 02:25 AM
Intercooler2's Avatar
Originally Posted by thecobrahunter
I also replaced mine with LEDs. Boy! What a difference!
Which type and all? Details
Old May 16, 2008 | 09:48 AM
wssix99's Avatar
Save the manuals!
Originally Posted by araber89
Shouldn't that OMSI site have the colors Blue Yellow and Red. Not green because you can make green with blue and yellow but you can't make Blue Yellow or Red
That's only with paint. Mixing light is different. Yellow + Blue light = White. Back down the blue and you'll see yellow. Add the blue and it goes white.
Old May 16, 2008 | 01:07 PM
thecobrahunter's Avatar
I used a pair of Varad Hyper LEDs. I cut off the stock bulbs (there're a bunch of threads on how to do this) and soldered the LEDs in place. I took a small drill bit and drilled the stock hole the light shines out and drilled it just large enough so that the led could be squeezed into. Used hot glue to keep it in place. and wah-lah! The LEDs come on whenever I open the doors, or when I turn on the headlights.
Old May 16, 2008 | 09:24 PM
"Grabby" 2000Z28's Avatar
Cool LED's
Pep Boys , LED's made by Pilot . They come in a 3 pack for like $6.00 . All colors , blue , red , green , purple etc.
Take off the door panel , cut the wires on the originals , poke out the old bulb and socket . The LED's come allready in a little black holder with about 4" of wire , put the wire through the original hole from the outside of the door panel . Push the bulb into the hole until the socket kind of "clicks" in place . The entire head of the bulb will shine on the outside and light up all your switches . Wire the two wires to the existing original wires you cut . You even have one left for a spare .
I have a Alpine stereo that lights up blue . I used blue LED's in the door and also put a couple blue LED's behind my speaker grills that draw power from my amps in the rear .
Old May 19, 2008 | 01:36 PM
Supposedly they are waiting at the house. I will post up a picture of them installed when I get home tonight. Look for it about 9:30 or so.
Old May 19, 2008 | 08:42 PM
They are in! Somewhat brighter but then again I didn't want it lit up like a spaceship. I used the piece of rubber tubing press fit over the bulbs and they come out easy. I did pull one of the LED's apart by not pushing the tubing all the way over when trying to pull it out. They work correctly... see pics of stock bulb with LED bulb. Very nice change for the dollars and I am happy.
Old May 19, 2008 | 08:46 PM
Stock #74 bulb
Old May 19, 2008 | 08:49 PM
T5 Flat 12VDC LED
Old May 20, 2008 | 01:33 AM
Sommer86's Avatar
NICE!! You know i'm still in!
Old May 20, 2008 | 07:52 AM
Hit me up with a Pay-Pal that has your address in there and I can get these out to you.
