Problems with stereo/wiring
Old May 15, 2008 | 10:50 PM
1blk97z28's Avatar
Default Problems with stereo/wiring
Hi everyone. I was hoping someone could help me with this problem:
I have a 97 Z28 and I am having trouble with some wiring (I think), or who knows what. My stereo will turn off randomly and then randomly turn on again. I noticed that when it turns off my power windows stop working as well. Sometimes if I open and close the door or tap on the side of the dash it will start working again just to turn off in a few seconds most of the time, and then possibly on again... It also sometimes goes off when I shift. I know there is nothing wrong with the stereo because this problem began since I had the stock stereo. I installed a Pioneer and the same problem continued. What's even more odd is that sometimes it will be fine for a few days straight and then it'll go wrong again. Yeah, so thanks for the help in advance.
Old May 16, 2008 | 01:51 AM
2SLOWT/A4NOW's Avatar
You need to perform a "wiggle test". Start wiggleing wires till you can get the HU to cut off. May take some time too. You have a bad wire in a harness somewhere. These kind of problems can be a real bear to track down.
Old May 18, 2008 | 12:47 AM
impstrz28's Avatar
are there any wires(power) in common with both the stereo and the power windows? look at some schematics that should help you narrow down your search to a few wires. i think.
Old May 19, 2008 | 02:52 PM
B-Unit01WS6's Avatar
Don't think there are any common fuses with windows and radio. They do share a ground under the left kick panel. Sounds to me like it's either that ground, or a few loose connections at the fuse panel on the left side of the dash.
Old May 19, 2008 | 10:48 PM
impstrz28's Avatar
a ground that makes sense.
