n00b stereo wiring question
Well, this weekend, I replaced the positive battery cable because it was really corroded. After getting everything back together, I'm not sure I want to cut the boot on the new cable and re-wire it the same way.
When re-running the new positive cable for the battery, one of the connections goes across the fans to the fuse box, where it has a ring terminal that is held down by a 15mm nut. Instead of cutting the boot and running the stereo fuse positive to that, can I get/make a longer cable and run it to the ring terminal on the fuse box?
Cliff's Notes: Can I wire the amp positive cable to the positive connection the battery has on the fuse box under the hood?
Sorry for being so long-winded. Just trying to describe this as best I can.
-Mike
you are better off getting a longer terminal post for the battery which is available at any car audio shop or knukonceptz dot com for cheap. this will allow you to leave the ring terminal on your new wire a full loop and itll stay better. I hate when shops jerry rig stuff.
Thanks for the help.
-Mike
