wiring a vm9311ts dvd player (EBrake)
Old Jun 16, 2008 | 06:01 PM
96t/acj's Avatar
Default wiring a vm9311ts dvd player (EBrake)
I have a jensen vm93llts, and i'm trying to figure out where is the ground located by the parking brake to wire the dvd player? It's a 00 trans am!
Thanks in advance for the help!
Old Jun 16, 2008 | 07:34 PM
WhiteBird00's Avatar
Ungrounded Moderator
You will find the switch at the base of the parking brake lever. It has a single tan with white wire and it grounds through the switch casing. Tap the head unit's parking break wire into the tan with white wire (do not cut the wire) and it should work properly.
Old Jun 16, 2008 | 07:39 PM
96t/acj's Avatar
ok thanks so much go i guess i need to remove the center console!
