Inno
Old Jun 16, 2008 | 11:47 PM
bryz28's Avatar
Default Inno
Does anybody have a Pioneer Inno and how do you use it with the Monsoon? I've searched and found lots of info in here on how to hook up an Ipod using the GM9-AUX but will it work the same for the Inno? I talked to the guy and Circuit City today and he said they could wire it directly to the Monsoon so there would be no FM interference. He also said they could wire a toggle switch so I could switch back and forth between the Inno and Ipod. I do not have the Inno yet and have not used the Ipod in my car yet but want to do both. I have a 2000 Z28 with the Monsoon single CD player but no CD changer. On the website it says the PIE-GM9-AUX must have the cassette player with CD changer controls which I do not have but I read in here you can. I think I have thoroughly confused myself. Any ideas? Thanks!
Old Jun 17, 2008 | 06:55 AM
WhiteBird00's Avatar
Ungrounded Moderator
The GM9-AUX provides standard auxiliary input through the CD changer port on the back of the head unit. You can use it with any device that can connect to a pair of RCA jacks (basically anything that has a headphone or other audio output jack). It does not have any iPod-specific features - it won't charge the battery and it doesn't provide any controls. You can use it for your Inno or your iPod. It will work with cassette head units from any model year but CD head units must be from 2000 or newer (actually, late 99 but it's difficult to tell an early 99 from a late one).
PIE also makes an interface called the X3 which allows you to connect up to three auxiliary inputs to the CD changer port with a switch.
