Electrical question? Need Help.
Old Jun 20, 2008 | 08:41 AM
95TAGary's Avatar
Default Electrical question? Need Help.
When I have my two amps playing and receiver I hear a loud pop and they shut off for a second and come back on when I hit the power button on my windows or sometimes have my radar detector on or hit a large bump in the road. I also noticed my alternator drops down to 10 amps when I'm at a red light but goes up to 14 when the gas pedal is applied. I have 200 amp alternator and everything has been working fine for two years but lately I'm getting this trouble. I also did the wire mod last year and wonder if this might be a problem? Anyone know where I can start to look? Wasn't sure why the power windows or cigarette lighter might be causing this? When this happens sometimes my dash lights flash as well so I know they must all be tied together somewhere but not sure where to look for the problem, my battery cables are tight.
Any Ideas? Thanks
Old Jun 20, 2008 | 10:56 AM
pentavolvo's Avatar
sounds like ur gettin a voltage drop somewhere or a bad connection. id start at the remote battery terminal under the hood i see them very rusty and corroded alot
Old Jun 20, 2008 | 09:10 PM
95TAGary's Avatar
I checked those and they're fine I have about a year old yellow top Optima.
Old Jun 21, 2008 | 01:39 PM
orion2247's Avatar
Does this happen when you try to roll down your window?
Your problem might be BCM or RAP related.
Old Jun 21, 2008 | 09:07 PM
95TAGary's Avatar
Yes when I roll down the window but also when I hit certain bumps etc. What does those stand for? Thanks
Old Jun 21, 2008 | 10:37 PM
Black00Z's Avatar
almost seems like a short or exposed wire somewhere based on the pop when you hit a bump
