Wire with power only when car is running
Old Jun 30, 2008 | 08:45 PM
silverado01's Avatar
Default Wire with power only when car is running
Is there a wire I can tap into that only has power when running. It will be turning on a relay so should not be drawing very much power.
thanks
Old Jun 30, 2008 | 09:08 PM
ls1rocker's Avatar
under the driver side dash, after you remove the panel below the steering wheel, there is a big pink wire. It's 12v only when the key is on. I use it to power my hardwired V1 radar detector.
Old Jun 30, 2008 | 09:35 PM
shoemike's Avatar
the fuse box has an open slot. (IGN)
Old Jul 1, 2008 | 06:59 AM
WhiteBird00's Avatar
Ungrounded Moderator
Does it need to be ignition controlled or live only when the engine is actually running? Ignition controlled is easy (shoemike's suggestion of the IGN port in the fuse box is the best option) but that is live when the key is on regardless of whether the engine is running.
Old Jul 6, 2008 | 06:36 PM
xRelapse13's Avatar
what exactly does this big pink wire power? Cause i've been thinking about the same thing with my Beltronics.
Old Jul 6, 2008 | 07:01 PM
That pink wire is the primary ignition wire from the ignition switch. Many people tap into it for accessories but it's not the smart thing to do. You should use the IGN port in the fuse panel as shoemike suggested - it was put there by GM for installing aftermarket accessories.
Old Jul 7, 2008 | 10:56 AM
xRelapse13's Avatar
thanks alot man
