Blinker problem
Old Aug 21, 2003 | 07:47 AM
Ackattack1's Avatar
Default Blinker problem
For some reason my blinker isn't working. My parking lights/blinker lights are on as normal, they just won't flash. Is there a flasher relay that needs changed? Where's it at?
Old Aug 21, 2003 | 11:36 AM
OctaneZ28's Avatar
Default Re: Blinker problem
Check the bulbs, usually if a turn signal stops blinking, there's a bulb burnt out.
If it is a flasher, there's 2 of them. One for the turn signals, one for the hazards.
They're both located under then panel below the steering column, hazard flasher about a foot to the left of the steering column, turn signal flasher about a foot to the right.
If you need to swap them, you may consider electronic flashers should you ever want to switch to LED bulbs. EL12 is the electronic flasher you'd need, and they're $8 each at AutoZone.
