HELP!!! replacing door speakers.......
Old Jul 8, 2008 | 10:40 PM
bdyman's Avatar
Default HELP!!! replacing door speakers.......
and it sounds like ****, iam using a 2 way pioneer gm replacment, i`ve searched, looked through here and found nothing, i really cant afford to buy more speakers, they are poping, center channle sounds like ****
one side works the other doesnt, is there a way i can wire then differently, iam doing this right now came in hopped on here for help
what should i do
gxp with monsoon
Old Jul 9, 2008 | 01:13 AM
fast01z28's Avatar
wait...what car is this? you say GXP with monsoon...grand prix? bonneville? solstice? G6?
either way, monsoon systems are amplified and cross over. chances are the ohm loads are incorrect on the pioneers an you might even have the wrong wires. give more info, like did your stock front speakers have a separate tweeter? is that tweeter still installed?
Old Jul 9, 2008 | 06:31 AM
bdyman's Avatar
yes grand prix gxp, seperate tweeter, everything is still installed, all the factory stuff is installed, the replacements pioneers are 4 ohms, iam using the wire for the factory 6 1/2 so what can i do
Old Jul 11, 2008 | 09:46 AM
imnotplutonium's Avatar
not much. you have to match the factory impedence and wattage to get the same sound. When upgrading to aftermarket speakers it is usually always a good idea to upgrade to an aftermarket amp to push em. monsoon amp = fail
Old Jul 11, 2008 | 09:09 PM
bdyman's Avatar
lol like epic fail right, so basicly i would need to push the speakers with an afremarket amp, and let the monsoon amp push my replacment speaker right??
