CD Changer Problems
Hoping someone here can help me out with some trouble I'm having with the stereo and CD Changer though.
When it arrived it was fitted with a Monsoon tape head unit and a CD Changer in the back. Don't think the changer is standard fit though - it's a Panasonic DP801 8 Disc Changer - but it all worked fine. To get the CD Changer to play I had to switch to FM2 (if changer wasn't on then FM2 would just play radio stations as normal).
However, I wasn't happy with the head unit as I wanted a CD instead of tape and because it was on the Japanese FM band I could only pick up 2 stations! So, I bought a 2nd hand Monsoon CD head unit that someone on here was selling. Fitted it a few days ago and the head unit itself works fine, however it won't work with the CD Changer. Switching to FM2 doesn't work.....it just plays whatever station is on FM2! I've tried hitting Aux/CD but that does nothing either.
Checked the connections and they are fine, switched back to the original unit and that still works with the CD changer so all I can think is that the original unit must have been internally modified in some way to switch to the CD Changer once FM2 was selected. The connections on the back of both units are the same and I guess the internals must be pretty similar, so I'm guessing it must be possible to get it to work with the CD changer like the original one did.
Anyone got any suggestions as to how I can get this working?
Cheers guys.
The other possiblity is that the original head unit was modified for the changer. That modification might be difficult to repeat without documentation.
I think you may be right about the FM modulator because I've just googled these things and seen a few images. Most appear to be smallish grey boxes and I've noticed that in the cavity behind the Monsoon is a similar looking grey box, which one of my friends said looked like something aftermarket. I guess this may well be the modulator. I'll take a look and see if there are any switches on it to adjust the frequency.
