sub box ?
Old Jul 31, 2008 | 08:26 PM
schuz_GXP's Avatar
Default sub box ?
Is there enough room in the hatch for a 3.81 cubic ft. box with out using the top flat area???
Old Aug 1, 2008 | 09:06 PM
cws T/A's Avatar
It would be tough to pull off without using fiberglass or something that forms around curved surfaces .
I achieved 2.58cu ft and it is a pretty big enclosure . I sacrificed the T-top holders and there mounting studs to fit it there meaning I can never put the holders back unless the studs were rewelded in .
I built mine a pretty simple shape as it was my first build . The raised area over the rear axle really makes building difficult . I choose a single 12'' as a result .
Here are a few pics for refrence ..
The blueprints :
[Note , the enclosure was built using 3/4'' MDF and 2 different measurements are shown , internal & external . ]
The box finished & loaded [weight ? around 50-60lbs] :
Installed in the car [ test fitting & final installation ]:
Special attention was paid to the corners [hand sanded] so the enclosure dropped down as flat as possible . My first build so it's not an experts job .
Everything you see no longer exists , I removed it after it was destroying the car etc . It is doing work on my Integra now .. fugg it .
Old Aug 2, 2008 | 08:29 AM
schuz_GXP's Avatar
thanks for the reply. It looks like if I used some fiber glass it could be done it's just been to damn hot here to work on anyhting outside.
