Radio staying on when car off?
He also said that the Monsoon was staying on on before he put the new HU in.
Do the interior lights or anything else also stay on? If so, the its the probably a door switch. The RAP (Retained Accessory Power) circuit keeps power to the radio and other accessories until a door is opened. If opening the door doesn't turn off the radio, then the door switch has failed. You can easily test that by opening the passenger-side door. If the radio turns off, then the driver-side door switch has failed. If the radio stays on, then (although possible) its unlikely that both door switches have failed. Unfortunately, the door switch is built into the latch. I don't know how to get to it (never tried). Sometimes its not an outright failure, but the switch needs to be cleaned or adjusted.
