Voltage Problem..
Old Aug 4, 2008 | 10:44 PM
Meen95z's Avatar
Question Voltage Problem..
I was looking for some help and thought you guys could help some.. I got a 95' Trans Am and the voltage when I start the car after sitting is about 12.5 volts, but as it runs drops to 11.0-11.2 and stays there according to my scanmaster. The gauge reads right on the yellow mark. I have 4 gauge ran from my battery to alternator, battery to starter, battery to distribution block for pos+ and 4 gauge for the gnd-.. I have a msd box, electric waterpump, 2 gauges, underdrive pulley with overdrive on alternator, stereo system all 4 gauge and capacitor.. Reguardless of the stereo being on or off it still discharges, no matter what rpm it never picks back up.. I have also tried 3 different alternators I have for my car, all do the same.. Any suggestions?
Old Aug 5, 2008 | 08:30 AM
Brian2006's Avatar
I have the EXACT same issue. Except at startup, I hover around 13.5 volts and it drops to the 12.5ish and eventually dips into the 11s if i drive it enough.
Did you try upgrading your ground wires? That's the next thing I'm about to try.
Old Aug 5, 2008 | 10:18 AM
Vicinity's Avatar
That's the opposite of my problem, lol. My alt is overcharging my battery. Have you tried a new battery for the hell of it?
Old Aug 5, 2008 | 09:28 PM
Meen95z's Avatar
well found out some new info, I have 14 volts at the battery and 11.6-11.8 in the car.. Some where im losing voltage..
Old Aug 5, 2008 | 11:17 PM
Brian2006's Avatar
Dido. Same here. Did you check it at the altenator?
Old Aug 6, 2008 | 02:35 AM
Meen95z's Avatar
yep, its fine also.. I dont know where to look for the problem now..
Old Aug 8, 2008 | 09:03 AM
Brian2006's Avatar
Figured out the problem? I'm about to do the Big 3 to see if that helps on my end
