installing sub question help and advice please
Old Aug 10, 2008 | 09:20 PM
larryndog's Avatar
Question installing sub question help and advice please
my firebird doesnt have monsoon and still has the stock headunit....i was planning on buying a 10" sub (rockford fosegate punch probably) a amp and a driver side stealth box...what else am i going to need? and this will work with the stock headunit?
thanks in advancee
Old Aug 10, 2008 | 10:05 PM
KEE AUDIO's Avatar
You need an amp, amp install kit and a line level converter. I actually have all of the above including the enclosures and subs if you want a package put together.
Old Aug 10, 2008 | 10:17 PM
larryndog's Avatar
you got a price?
Old Aug 11, 2008 | 07:57 AM
No Juice's Avatar
To expand on this a little:
If I've got the amp install kit and line level converter, where is the best place to get the switch/signal from so the amp turns on and off with the radio?
Old Aug 11, 2008 | 08:45 AM
EW1's Avatar
EW1
I just installed my system in my 99 z28, use the RAP power wire - yellow wire in black connector. Works out perfectly. I also got the input for the converter from the back of the head unit. Thanks to whitebird00 for the info.
Old Aug 11, 2008 | 10:41 AM
larryndog's Avatar
so i need an amp..amp install kit...and something like this http://www.electronixwarehouse.com/c...ramid-ns60.htm
Old Aug 11, 2008 | 10:42 AM
larryndog's Avatar
or do i need something like a rockford 3sixty
