Got an interesting email from Sirius
* If you listen to your SIRIUS radio wirelessly through your vehicle’s FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
* If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the “FM On/Off” menu item and then press the SELECT button. Use the up/down buttons to highlight “FM Off” and press the SELECT button. To exit the “FM On/Off” menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below.
I already have one installed now in my car so I think i'll be selling this one on ebay.
My Original sportster would broadcast through my whole house and I could pick it up on any radio even shiti clock radios.
Now with the Sport 4 I had to install those antenna kits cause I couldn't keep a clear channel while driving. PITA!
F- THE FCC!!!
