Remote wire for amp to cut it off
Old Aug 19, 2008 | 06:45 PM
contemptor's Avatar
Default Remote wire for amp to cut it off
My friend helped me set up my sub a while ago. It works... except it doesn't cut off when the car does. The power cable is connected directly to the battery, and the remote wire is spliced to a blue wire of the same color behind the headunit :o I assume it needs to be spliced to a wire that only has power when the car is on ACC or on.... how do I find out which wire I need to splice it with?
My headunit isn't stock btw... sony 5700cdx
Old Aug 20, 2008 | 07:00 AM
WhiteBird00's Avatar
Ungrounded Moderator
The aftermarket head unit should have a remote turn-on wire that is blue with a white stripe. The plain blue wire is for power antenna control (assuming that your head unit uses standard wire colors).
In the factory harness, if you have a Firebird, you can connect the remote turn-on wire to the power antenna control wire (pink wire in the black connector) - it has power only when the head unit is on. In a Camaro, your only choice would be the accessory power wire (yellow wire in the black connector) - it has power whenever the ignition is on and during RAP operation (after the ignition is off until you open a door).
Old Aug 20, 2008 | 09:17 AM
contemptor's Avatar
In the factory harness, if you have a Firebird, you can connect the remote turn-on wire to the power antenna control wire (pink wire in the black connector) - it has power only when the head unit is on. In a Camaro, you're only choice would be the accessory power wire (yellow wire in the black connector) - it has power whenever the ignition is on and during RAP operation (after the ignition is off until you open a door).
The power antenna is a light blue one and labeled thankfully, so I know which one that one is. I have it connected to a blue wire... but idk about a white stripe. I'll check it out and see.
Old Aug 20, 2008 | 11:42 AM
whitew01ws6's Avatar
not all head unit have the white stripe with the blue wire..... but i do know that kenwood head units do
i just recently made that mistake, normally u splice blue to blue... well it was blue to blue white striped
Old Aug 20, 2008 | 12:09 PM
The EIA standard calls for a blue wire for power antenna control and a blue with white wire for remote turn-on. Kenwood, Pioneer, Alpine, and most other major brands all follow the EIA standard.
Old Aug 20, 2008 | 05:23 PM
contemptor's Avatar
Thanks man, my (different) friend today was swearing we should just use the red or blue wire but we tried the blue-white wire and it works
