Pulley and Alternator Upgrade for New System
I've got a new complete system on the way from Ian at Kee Audio:
JVC KD-AVX44 Headunit
CDT E61-CV - powered by stock monsoon amp
Bazooka's for Sail Panels - powered by stock monsoon amp
Pioneer GMD7400 Amp (400W RMS)
CDT HD-10 Sub (400W RMS...maybe 500...can't remember)
I'm also running HID headlights and because my other battery is dieing, I recently purchased an Optima Yellowtop battery from Autozone ($135 after rebate!) but have not installed it yet. It is the D34-78 version.
Should I get a HO alternator (and upgrade the stock power cables)?
Should I get the overdrive alternator pulley?
Both?
I just want to make sure that I will have zero issues running the new system.
Thanks!
I suggest you try it first without upgrading and see how it goes.
SCREAMIN01SS - I might be in touch with you in the near future, but changing the alternator pulley is just to balance out the underdrive pulley so that it produces stock amperage. You only make it produce less than stock if you DON'T change the alternator pulley.
(1-.25)*(1+.15).
The best thing to do is play around with it all, everything hooked up with HPF on HU set to 120Hz and sub amp set to 120Hz, then start playing with the filters and disconnecting speakers (sails and/or hatch) until you get something you like.
Let's try to stay on topic.
Quote:
Originally Posted by A 2000 SS in Jersey
Stupid question
I understand the principle of underdrive...........butttt.
Does this pulley drop the speed of everything by 25%?
Alternator, power steering, AC.??? I assume yes, but assuming gets me in trouble.
If so, any negativee effect on perfomance? Such as lower Battery volatge, worried about PCM getting full voltage and such? Ac and or power steering. And the big one!!!!!!!!
How much power are we talking about......... Extra to my BUTTT..LOL
Thanks
The answer I got was:
"You really need to do a search."
The author was:
matts22
Stupid question
Thanks
The author was:
matts22
