Radio Static
Old Sep 6, 2008 | 01:57 PM
machsv103's Avatar
Default Radio Static
Im using the stock head unit with 2 amplifiers running the speaker and when i listen to the radio I get alot of static. The cd player works fine and sounds great. Any idea why its staticy?
Old Sep 7, 2008 | 03:50 PM
99Bluz28's Avatar
Question
Is this with FM or AM, some or all stations? Did it do it before you installed the amps? Have you already checked the antenna cable connection fron the radio to the antenna ?
Old Sep 8, 2008 | 01:21 AM
machsv103's Avatar
It worked fine before I installed the amps. Its both AM and FM the only thing I can think it is would be that the power wire is to close to the antenna wire but I made sure when i ran the power wire that it was no where near it.
Old Sep 9, 2008 | 02:38 AM
99Bluz28's Avatar
Thumbs up
Double check the antenna cable connection from the radio to the antenna,and the cable itself.
If you think it's the amp try moving the amp ground location, and see if that helps.
Old Sep 11, 2008 | 02:33 PM
import_raper's Avatar
Yeah, I agree sounds like your antenna's not connected.
