Just installed my Auto Trix window fix
Old May 6, 2009 | 04:56 PM
  #41
starfishy's Avatar
Is there a way to combine the fix with the DEI530t? I have had a 530 in my car for a few years now and I don't know how complicated it would be to replace it.
Thanks
Christian
Old May 6, 2009 | 05:27 PM
  #42
gnomee's Avatar
Thanks
Christian
No problem.
Just wire the kit in between the switch and the DEI. So in the the install instructions you would treat the DEI as the "motor" and wire accordingly. Therfore giving the DEI direct power from the battery and allowing it to still control the power to the motor and detect when the motor has reached down or up.
Hope that makes sense.
Old May 6, 2009 | 05:36 PM
  #43
SparkyJJO's Avatar
I need to do this. My passenger window only makes it to the top in one try when the car is running. On battery it usually gets almost there then stops, and I have to hit the button again to get it up fully.
Old May 19, 2009 | 05:40 PM
  #44
SparkyJJO's Avatar
Ordered the kit from WS6store, fast shipping from them!
Took a good couple hours to install, the hardest part was getting the power source. The nut on the battery connection over at the fuse block wouldn't budge so I had to come up with something else. Ended up getting power from an unused spot in the block.
My original passenger window motor, which was struggling to make it to the top, now operates faster than my driver side with a much newer motor! Awesome
Old May 20, 2009 | 04:31 PM
  #45
gnomee's Avatar
Monday car or not, you should be done with passenger window motor problems
Don't forget to leave a review on the ws6store.com website!
Old May 22, 2009 | 12:10 PM
  #46
blackodium's Avatar
where is the kit for both driver and passenger. i dont have slow motors yet knocking on wood....
Old May 22, 2009 | 12:16 PM
  #47
blackodium's Avatar
found it thanks
Old May 22, 2009 | 12:49 PM
  #48
dreamls1's Avatar
i need one bad!!
Old May 24, 2009 | 11:00 PM
  #49
ShowstoppaTransAm's Avatar
hey i just installed the pass express and front blinker mod while the car was in the shop getting the lambo doors removed. i love it!!!!!! just had to wait about a month and a half to get it after i paid. that part totally sucked!!!! i recently installed a new motor and regulator so hopefully with this mod i want have to worry about changeing the motor again.
Old May 29, 2009 | 07:33 PM
  #50
gnomee's Avatar
Glad to see everything went smooth for you.
What made you go through the expense of removing the lambo doors?
Old May 30, 2009 | 08:42 AM
  #51
slickone's Avatar
About how long did the install take you guys
Old Apr 5, 2011 | 12:41 AM
  #52
Anderson0741's Avatar
I cant find these on the site
Old Apr 15, 2011 | 03:13 AM
  #53
jr's camaro's Avatar
would this kit work for the driver side too because both of my windows are slow and i just replace the motor and the still don't roll up and down right and they sometimes the get stuck
Old Apr 15, 2011 | 07:41 AM
  #54
mrrman's Avatar
Ive got the same issue with the windows going so slow on my 87 TA...Ive decided to just replace the motors...at $49/pair...why not
Old Apr 15, 2011 | 08:27 AM
  #55
99monguse's Avatar
Has anyone taken these kits to a repair shop and had them installed? If so, what did they charge you to install them? I want to biuy the driverside express down and the standard passenger side kit for both of my Camaros but I don't mess with wiring, I'm trying to get an idea of what the labor time/cost is?
Old Apr 15, 2011 | 08:41 AM
  #56
Wimimc's Avatar
http://www.autotrix.net/Catalog-93-02-Camaro_2.aspx
i was wondering the same, i posted a thread asking about it but didnt hear too much. they have an express kit for the drivers side which gives it a one touch roll down (which we have) and speeds the process up.
Old Sep 8, 2015 | 12:38 PM
  #57
bigz28man's Avatar
Hey guys I just got this kit from ws6store. Just curious about how long it took to install.
Old Sep 13, 2015 | 02:35 AM
  #58
jeffz's Avatar
Post #44 said 2 hours.
Old Sep 18, 2015 | 11:56 AM
  #59
Spectre86's Avatar
damn. looks like this is going to be next on my list
can I just use the passanger on the drivers side if I don't care about the 1 touch option?
https://www.autotrix.net/Products/10...indow+Fix+Kit/
I don't mind holding the button for a few seconds to save $100. lol
Old Sep 18, 2015 | 12:13 PM
  #60
SSickLS1SS's Avatar
on their website it says that you can use for both windows
