Getting rid of engine bay fuse box... nd help
Old Oct 8, 2008 | 08:54 PM
InsaneAuto86's Avatar
Default Getting rid of engine bay fuse box... nd help
I am trying to do a full wire tuck of the engine bay. As you can see in the pics below, I am only using 10% of the large engine bay fuse box. Is there any way to consolidate the parts I am using? I want to put the remaining part in the car under the dash. Thanks.
Old Oct 9, 2008 | 05:18 AM
99345hp's Avatar
If its just fuses and relays you need to use you could use a universal fuse and relay box from summit. Then just run all your wires to it.
Old Oct 9, 2008 | 06:48 AM
I would but the wires dont make sense. For example, when I look under the fuse box, the wire running to the fuse is not attached at the other end of the fuse. Looks like a series type of wiring, which I do not have a good understanding of.
