I did it finally!!!
I did it finally!!!
Ran my first 10 of friday night. My best before was 11.4, i installed some air bags in the rear and screwed my tires in and boom ran a 10.90 at 126 with a 1.55 60 footer. Will post slip and vid soon.mods in sig.
The car is full weight, probably heavier with the 9inch. It was about 40 degrees out.
Just finished my newer setup over the weekend, ill be hitting the track on the june 10th. Added tsp ls6 heads, fast90/90,svo injectors and a built t-56 trans.
The were about the same, the only reason i did the air bags were to try and help the fact that every time i shifted it would go side ways and i was having trouble figuring out what the problem was. The air bags did striaghten it out a little with pulling the wheels off the ground. It would pull them evenly now.
Yeah I really want to go just for a relaxed day of smokin some rice. Its import war day. So unless i have somthing really more important than drag racing which i highl doubt we will go.
