11 Second Club Snake eyes are a good thing
11.55
Old 07-18-2012, 05:45 PM
bricco1029's Avatar
Default 11.55
Went to the track last wednesday and pulled a 11.55et at 119.63 1.69 60ft
fastest ive been so far! this is with a stock stall. just got a Midwest Converter 3500 stall and going to the track this friday for RSDs (Real Street Drags) hope its even better.
Will upload pic soon of time slip!
Old 07-18-2012, 05:53 PM
bricco1029's Avatar
Hard to see
R/T .063
60' 1.698
330 4.847
1/8 7.429
MPH 95.65
1000 9.663
1/4 11.551
MPH 119.61
The other lane was against a 2012 Lotus Exitige hehe
Old 07-18-2012, 08:04 PM
99Custom's Avatar
Hell Yeah...
Old 07-18-2012, 08:12 PM
gs462's Avatar
119 mph is damn near 10 second MPH you should be in the low 11s with that 60 ft time.
Old 07-18-2012, 08:58 PM
bricco1029's Avatar
Well its a bolt on car with a 150 shot, hoosier DRs, and some suspension work. and now i just got that converter and ill be there this friday making a few passes. will will see!
Old 07-21-2012, 07:40 PM
82cetuner's Avatar
i trap at 119 myself on street tires running 12.2s I came in here to see what I should be running one I put the skinnis and slicks i was hoping for 11.5s nice to see there definetly within my reach
Old 07-21-2012, 08:01 PM
Nemesis350's Avatar
with your setup i'm surprised you're not at least mid 11... stop sandbagging! lol
Old 07-21-2012, 09:58 PM
Jarred Hodges's Avatar
what does it run on motor
Old 07-22-2012, 12:16 AM
bricco1029's Avatar
all motor is a doggg 13 flat. even with the new 3500 stall. Spaying with the stall i got 11.43. and 118 It's shifting way to high now because of the slippage from the converter. It was previously tuned but now i have to get my shift points lowered by at least 500 rpm. im way outa my powerband its just slowing me down.
Old 07-22-2012, 07:57 AM
gs462's Avatar
11.5 should be pretty easy assuming you can hook the car up with a good 1.6
60 ft you should run 11.2@ 119 MPH
Old 07-22-2012, 08:15 AM
Captain Double Post
BOBS99SS's Avatar
Put a cam in there and spray a 200, that will get that bad boy moving lol,good times though
Old 07-25-2012, 11:05 PM
82cetuner's Avatar
yeah 11.2 is exactly what a dyno showed me on a simulated drag pass. I just could never hook for crap on street nitto 555s and the track I go to is pretty horrible on traction as well so Ive been doing 2000rpm launches(well below my power band) and still spinning once I get into my peak torque threw 1st second and third im just hoping for 11.5s or under at that track and to not break anything. I got 26x11.5 MT et street slicks and some skinnys up front now so should put some nice times down will find out saturday
Old 07-25-2012, 11:06 PM
82cetuner's Avatar
plus my setup is not the best for drag racing or sixty foots, I also run a lighter than stock flywheel.
Old 08-04-2012, 06:16 PM
any updates
Old 08-06-2012, 01:56 PM
sabersaw30's Avatar
Here is a calculator manual and auto under perfect conditions.Lowest mph you should be able to get at a set time.Found this in a old car craft and had to laminate it and put it in my wallet.[IMG][/IMG]
Old 08-06-2012, 03:39 PM
82cetuner's Avatar
id say thats pretty accurate giving best case scenario and probably 1.3 sixty foots LOL
Old 08-06-2012, 03:43 PM
82cetuner's Avatar
well my car did a best of 11.7 with a 1.8 sixty I know thats still pretty weak but I was just learning the slicks and playing with tire pressure I ended up not making any more passes right when I started hooking and figuring out tire pressure it was also super hot. i am sure if I had kept at it a 11.4 would of been possible that night. I did break 120mph trap speed on the last run though.
The motor is comming apart sunday due to a failed lifter I found lots of metal in the pan and filter. oil pressure is still good so I am going to do a cam swap and replace the lifter and hope the bearings didnt take any damage, but if they did I willf ind out soon enouph then I will just do a whole rebuild. Since I have to tear into it i am going with a bigger cam and going to deck the heads to get 66cc chambers and move to a 40 thousands head gasket to bump it to 11.9 compression
Old 08-06-2012, 07:56 PM
sabersaw30's Avatar
Yeah you deffinately have to hook to run what is on that card.
Old 08-12-2012, 12:38 AM
NW Iowa WS6's Avatar
Im guessing about a 1.5 60ft for those mph, chris1313 on here did 10.08@131 with an auto and 1.3 60ft and this is saying 10.2@132.5
Old 08-17-2012, 05:50 PM
chrs1313's Avatar
I will take a lane with you at RSD...
But I am just a n/a stock bottom end car so I will need the hit with you on the bottle...
Quick Reply: 11.55
