12's finally! possibly 11's with a tune!!!
Went to a test and tune, with some DR's and a good amount of VHT I finally got it 12.301 @ 107.9 1.71 60' mods in sig. Heres a vid.
http://youtube.com/watch?v=fYWCASdOhWA
Like its slipping? I havent had it tuned so it hits the limiter for a second when it shifts into 3rd everytime. But its only for a second. I am hoping with the tune it should help out.
On my other runs 12.50's I was trapping 110. But with the lower 60' faster ET I thought it was normal to have a lower trap speed.
should be a little faster. i would think once the car is tuned for the converter (shift points need to changed) then you'll see some better mph.
also - with that stall and gears you should have no problem cutting 1.6x 60' times even with a full weight car.
if you can't dead hook the car on launch then you'll need more suspension.
http://www.ls1speed.com/catagory.cfm...%20/%20Chassis
we have PLENTY of choices. i would recomend your next suspension mod being a torque arm. feel free to call me if you want advice as to which one would best suit you.
right now i don't see a reason why it couldn't be a 12.0x car.
agreed - 12.30's in a full weight car with a stock internal motor is really good.
if he cut a 1.60 short time on that run he'd be in the 12.1x's
once the shift points are optimized he could see another tenth or two - having that big of a converter without the shift points optimized can have a big affect on e.t./mph
Also when its tuned depending on the power curve it may bump the limiter up a couple hundred RPM if its making power still. I should be getting it tuned and back out the the track in about a month or so. Hopefully with the tune and some MT's it should hook a little better.
