Advanced Engineering Tech For the more hardcore LS1TECH residents
Help with compression ratio
Old Mar 15, 2012 | 06:54 PM
ksk1980's Avatar
Question Help with compression ratio
What i have is a 6.0 iron bored .040 using stock rods n crank n pistons are flat tops. Machinist said from his calculations the piston tops come above the deck .02 (this normal?) , heads are 243's plan on milling. 010 to clean them up n bump compression just a tad bit. Running a 224/230 .604/.609 lsa 112 and planned on using stock lq9 head gaskets. Whats my comp ratio gonna be? Any issues that stand out on this setup?
Thanks in advance
Old Mar 16, 2012 | 01:49 PM
Mr. Sir's Avatar
Maybe this will help:
https://ls1tech.com/forums/advanced-...ume-vs-cr.html
And also, try posting this in the gen 3 internal section. This isn't advanced engineering.
Old Mar 19, 2012 | 03:03 AM
C5natie's Avatar
Here is a compression ratio calculator. Just enter your specs and youll have your answer. Also check for piston to valve clearance.
http://www.csgnetwork.com/compcalc.html
Old Mar 19, 2012 | 04:14 PM
ksk1980's Avatar
Thank u c5
