Advanced Engineering Tech For the more hardcore LS1TECH residents
Bad calculations?
Old 03-04-2014, 08:46 PM
Cthulu's Avatar
Default Bad calculations?
I'm calculating the stock compression ratio on a 2002 LS1 with the below stock specifications and getting a static CR of 10.36:1 instead of the expected 10.1:1
Is my math wrong? I apologize is this is a noob post, trying to understand where I'm going wrong. I have the negative values in there for Deck clearance volume. I noticed when I take those out it goes back to 10.17:1
5.7 LS1
Bore 3.898
Stroke 3.622
Number of Cylinders 8
Displacement 345.7896451
Chamber Volume 4.068453019
Swept/Cylinder Volume 43.22370564
Gasket Thickness 0.054
Gasket Volume 0.644417478
Rod Length 6.098
Compression Height 1.339
Deck Clearance -0.008
Deck Clearance Volume -0.095469256
Deck Height 9.24
Piston Volume 0
Compression Ratio 10.36104605 (cylinder volume + clearance volume + piston volume + gasket volume + chamber volume divided by clearance volume + piston volume + gasket volume + chamber volume)
Old 03-05-2014, 12:00 AM
Cthulu's Avatar
So, I redid all my math including the below added variables...still getting 10.36:1 for a stock LS1. Can someone point out what I'm missing?
5.7 LS1
Bore 3.898
Stroke 3.622
Corrected Stroke (minus deck) 3.63
Gasket Bore 3.905
Gasket Volume 0.646734036
Piston to Head Volume 0.550921587
Rod Length 6.098
Deck Height 9.24
Piston Volume 0
Ring Height 0.3
Piston to Bore Clearance 0.0021
Crevice/Clearance Volume 0.003856428
Piston to Headgasket Volume 0.003863356
BDC Volume 47.94274912
TDC Volume 4.623237961
Compression Ratio 10.36995057
Old 03-06-2014, 12:25 PM
Cthulu's Avatar
I still don't understand why I'm getting 10.36 as my compression ratio instead of 10.1:1, Does anyone see where I'm going wrong? A second look by someone would be appreciated.
Static Values below
Bore 3.898
Stroke 3.622
Gasket Bore 3.905
Gasket Thickness 0.052
Rod Length 6.098
Compression Height 1.337
Deck Clearance -0.006
Deck Clearance Volume -0.071601942
Deck Height 9.24
Ring Height 0.3
Piston to Bore Clearance 0.0014
Piston Volume 0
Calculated Values
Gasket Volume 0.622780924
Crevice/Clearance Volume 0.002571183
Piston to Headgasket Volume 0.002575801
Below added for BDC Volume
Piston Volume 0
BDC Volume 47.91751076
Below added for TDC Volume
Piston Volume 0
TDC Volume 4.621950407
Compression Ratio 10.36737882
Old 03-06-2014, 03:58 PM
ez2cdave's Avatar
Try using this Compression Calculator . . .
Be sure to enter all of your values as POSITIVE numbers ( i.e.- "3cc" for -3cc Flat-Top pistons ), same for Deck Height.
http://www.diamondracing.net/tools/
Old 03-06-2014, 05:07 PM
Cthulu's Avatar
Well, that's not quite the point. That calculator comes up with 10.17
Which is great, but I don't have the formulas on how it did it. So how do I really trust it?
Old 03-06-2014, 06:09 PM
ez2cdave's Avatar
Hmm . . . How did you compute your CR before ? Can you trust that method ?
If I can, I'm going to send you an attachment in a PM, if I can . . . If not, we'll use e-mail .
Quick Reply: Bad calculations?
