2001 ws6 cam nitrous heads build
Hey guys I just purchased a 2001 white ws6 with 22k miles I recently have installed a ms4 comp cam with new push rods valve springs ect. I also installed a set of pacesetter headers with the matching ypipe and borla exhaust has a ls6 oil pump slp airlid and a nx wetshot system was also recently installed.I had a performance 460 le trans built with a
3800 yank stall. I need some oopinions on which gear I should go with 373s or 410s? Also the car has 241 heads if I wanted to swap to the 243s would I need all new supporting hardware or with all the valve springs ect still work? Or should I just buy a set of built ported and polished ls6 heads? Im new to the ls1 game all advice would be very much appreciated thanks!!!
Its a 150 shot sorry I didnt mention that! How much power should this setup make roughly? Im really curious about the heads if I.should port my 241s or buy a set of 243s and have them done but I want to know if all of valve springs ect will still work in the 243s or if I should just buy a set of trick flows or something along those lines
