Sponsored by: DashLynx
Questions about boost and fuel pressure gauges.
Old 02-16-2009, 09:14 PM
joblo1978's Avatar
Default Questions about boost and fuel pressure gauges.
So, my blower install is going, slowly I decided to start with my gauges, get some interior stuff done first.
I had a few problems and could use some help.
The gauges are in and wired, they look awesome, autometer cobalts in a dual pillar pod but...
That polyester tubing for the boost gauge is terrible. It's like weed wacker line almost, or worse. I ended up breaking it, so where can I get more, and what else could be used that is easier to route instead of that?
Also, how does the fuel presssure sending unit connect to the schrader valve? I guess I need another fitting or something?
Thanks in advance for any help.
John
Old 02-17-2009, 03:36 PM
lazerman's Avatar
Just do a search for plastic vacuum line.. You may need a brass fitting (like the brass fitting on a copper water line) to make the seal.
Old 02-17-2009, 04:16 PM
coco95z28's Avatar
i used a steel braided hose for my fuel sender. (the hose screwed right on the schrader valve)
BUT i did need a fitting that screwed to the sender unit/braded hose...
Quick Reply: Questions about boost and fuel pressure gauges.
