Sponsored by: DashLynx
Bulb to LED List
Old 02-03-2010, 01:14 PM
  #41
ec_nova's Avatar
just ordered a complete interior set and some kickass reverse LED's ( i have 5% tint need all the light possible lol) will post pics when it's all installed
this is the reverse LED I will be using
Old 02-03-2010, 01:19 PM
  #42
omarrakeen's Avatar
Originally Posted by dhowdy
I believe you need two 3mm LEDs for the odometer and ten for the monsoon head unit as well (need resistors too). Only thing I couldn't find was how to change the color of the display on the monsoon HU. Any thoughts?
*edit* While I'm posting about lights...which ones do I need to replace the side markers? I vht'ed them a little dark and am looking for something brighter. Thanks.
what about the guages?? mine are getting dark and sometimes they wont lit..is it easy to replace and how does it look ? my head unit came LEDed with blue led it looks pretty nice..
Old 02-03-2010, 01:32 PM
  #43
jdoyle's Avatar
can anyone PM me a link of where they got the dome light LED for their '99 car?
Old 02-04-2010, 12:34 AM
  #44
stealth355tpi's Avatar
here is hcool white in a camaro cluster, only thing not done yet is the steering wheel controls. sorry i couldnt get a clear pic.
Old 02-04-2010, 12:47 AM
  #45
t/afrom504's Avatar
What LEDs i need for the lights in the backseat, I have a vert if that helps?
Old 02-04-2010, 03:10 AM
  #46
fbodyrs96's Avatar
RL4410-xHP9 Rigid loop Festoon bulb
Old 02-12-2010, 05:27 PM
  #47
jdoyle's Avatar
RL4410-xHP9 Rigid Loop Festoon bulb
Does anyone know if this bulb will work for the dome light of a '99 car?
Thanks,
jdoyle
Old 02-17-2010, 06:10 PM
  #48
Sykokilla's Avatar
Thanks,
jdoyle
Yea man it will work. I got mine in and I have a 98'. works great.
Old 02-18-2010, 02:40 PM
  #49
SuperDave479's Avatar
Anyone know what to use for a license plate LED? I just want to replace the existing bulb with a LED one to give it a whiter light, not necessarily brighter.
That's the main thing for now but I'm also curious about which ones I should use for my reverse lights. I want to do the same thing there.
Old 02-18-2010, 03:41 PM
  #50
fbodyrs96's Avatar
#194 for the license plate.
Old 02-18-2010, 03:55 PM
  #51
Black_Z28's Avatar
Anyone know which bulbs would be the best fit for the rear tail lights, and reverse light? I tinted my tail lights, and need a little more output, since they got just a little too dark. Also, should I go with red or clear color? Thanks.
Old 02-18-2010, 05:33 PM
  #52
Mike@ZMS's Avatar
I vote Sticky!!!
Old 02-18-2010, 05:47 PM
  #53
blackodium's Avatar
has anyone used the ones that look like that but in red for the tail lights?
Old 02-18-2010, 07:29 PM
  #54
Thanks, but I'm trying to figure out the LED equivalent at around the same brightness. I selected that on the superbrightleds site but it gives me like 6 choices.
Btw, love your car. One of my favorites on the site.
Old 02-19-2010, 12:23 PM
  #55
ginop524's Avatar
does anyone know if its possible to change the bulbs that illunimate the window switches... and if their is a bulb how do you remove the old ones, i cant get them out for my life.. do you have to cut and splice if possible at all. thanks
Old 02-20-2010, 07:35 AM
  #56
fbodyrs96's Avatar
bulb #74 pull out with pilers
Old 02-20-2010, 07:37 AM
  #57
fbodyrs96's Avatar
the more LEDs the brighter, but the hole is really small, may not have much choice on which led will fit.
Old 02-22-2010, 04:18 PM
  #58
Irish350's Avatar
any reason why the door lights wouldnt work but the other courtesy lights do?
maybe the lights need to be pushed in deceptively far (into the housing?)
ive got nice white lights now, but the doors are still dark.
Old 02-23-2010, 02:03 AM
  #59
offroadfury6's Avatar
so 5 of the SMD5 wont work for the cluster?
Old 02-23-2010, 02:58 AM
  #60
ZexGX's Avatar
I have used tape to tightly sandwich the old bulb in, then the tape grips the bulb and provides a handle to pull the old bulb out by hand without destroying it.
The courtesy lights are on a different circuit than the door lights. The door lights are wired to come on when the Parking lights and Headlights turn on. Another possibility is you might need to pull the LED and flip it 180 degrees to reverse the polarity. The door lights also have a red plastic embedded in the female end of the bayonet system, so even if you put a white LED in, only red light will shine through until you take a Dremel and drill out the red material
Quick Reply: Bulb to LED List
