Sponsored by: DashLynx
HELP* LED tailight, brake light, rear turn signal replacement..
Old 04-27-2010, 01:49 PM
will8908's Avatar
Question HELP* LED tailight, brake light, rear turn signal replacement..
Ok. So pretty much every light in the rear of my car is barely visable due to the fact that my lights have been smoked (tinted..whatever). I would like to just go through and replace every light back there with a much brighter LED bulb. However, I know there are other things that you have to replace like electronic flashers or something? If someone could fill me in on this process step-by-step itd be great! Thanks.
Old 04-27-2010, 07:58 PM
Irish350's Avatar
if you use this list
https://ls1tech.com/forums/appearanc...-led-list.html
and then hop on any of the probable non-sponsors; vleds, superbrightleds, etc i believe they have a conversion chart, from stock to led and smg. Id recommend going smg if you really wanna do this, but keep in mind tas have 6 reds and 1 white per rear, plus youre doing the rear corners and 3rd.
LED swaps never seem to be 'cheap', but IMO theyre always worth it.
might also look into getting new housings and actually tinting them, if theyre actually painted (tint is much more opaque and lets light through. im sure you understand)
Old 04-27-2010, 08:03 PM
TooFast3800's Avatar
I have looked into this at one time and to do ALL the lights in and outside the car except the headlights it was almost $350 for LED's. I just did the interiors, side markers, and license plate light. Oh and the front turn signals. Had to buy an EL12 flasher to make them work.
Didn't do the tail lights because the bulbs were $$$ expensive. Goodluck.
Old 04-27-2010, 11:32 PM
Ls1CamaroGuy87's Avatar
Use SMD towers instead of standard led towers.....they are much brighter. I used resistors for the brake lights, which you can use for any other light as well.
https://ls1tech.com/forums/appearanc...se-lights.html
Old 04-28-2010, 12:51 AM
Irish350's Avatar
lol, i said smg in that post.
also while youre at it...
https://ls1tech.com/forums/appearanc...il-lights.html
Quick Reply: HELP* LED tailight, brake light, rear turn signal replacement..
